- 317
- 141
- 43
- Rutherfordton, NC
At this point, appreciate what help was given. Lock it up.
64 post later... So what was the problem? And they call it a "Smart Box" LOL.Start box was bad. Swapped in loaner, light worked correctly and plugs working fine.
Well, as noted the ground was not returning through the box to initiate the wait light coming on and plug activation. I have looked over the bad box but really don't see any devious spots of corrosion or burns. Maybe one of those little diodes or a bad solder joint? No answer there. I think I will find an electronics guy local to run through it and see if it can be salvaged.64 post later... So what was the problem? And they call it a "Smart Box" LOL.
The END, CAMO.
