Ray70
- 5,910
- West greenwich/RI
Hello,
I'm working on an 806A for someone and the coolant temp sender in the corner of the head is broken. ( somehow the wire and center pin have come out of the casing and were dangling behind the head )
Looked in the TM and it gives a PN of:
Beede 127341 , 5905-01-376-0985 , 88-21742
Unfortunately a google search of these 3 numbers really didn't find me anything that is correct and available.
I was curious if anyone knows of a source for one, or if there is a known replacement that works?
I was also thinking that since the gage in the 806 is the same as the 802/803 etc. I wonder if the sender from an 802/803 would work if I find a brass bushing to step up the thread size to the 1/2" NPT needed for the 806?? Should use the same resistance range I would assume.
FYI, the TM says the sender should be >300 ohms at ambient and drop as engine temp increases, that's all I found for specs on the sender.
