blutow
- 500
- 63
- Austin, TX
I'm doing some research on registering a humvee in TX and ran across the following info.
If this is the latest info, it looks like you are only allowed to register as a regular vehicle if the gross vehicle weight rating is under 10k lbs. Otherwise, you have to go with antique registration (which are allowed for military vehicles). The antique registration has some pretty tight restrictions and I'd prefer to get a regular registration with no limitations. I'm looking to get an M1123 and they all have a weight rating of 10,300 from what I've seen. I know many of the older models have lower weight ratings, so I'm guessing that's why the limit was originally set at under 10k. That's a pretty silly limit though since many "normal" pickup trucks have a weight rating over 10k these days.
Anyways, does anyone have experience registering a humvee in TX with a weight rating over 10k? Is this going to come down to luck of the draw with the person at the title office? I guess the antique registration would probably be good enough with my limited use (just take my chances), but would prefer to get it registered as a normal road vehicle. I'm in Travis county in central TX if that makes a difference.
