Floridianson
- 2,503
- Interlachen Fl.
I just got the 925 and was going to do the battery relocate thing. I have removed the battery box and stuff to redo the floor and deal with a little rust that was there because of the rubber mat. Ok can anyone help me with this problem. I know that wire # 569 is 12volt pos. but here is what I have in the pic. The heavy wire that does not have a tag and has been spliced with the white wire was on the Neg side of the 24 volts. Was this correct. Then I have the outher two smaller wires. The large starter Neg has a smaller wire in it's harness and marked Gnd A and this was on the 24 neg. side and that seems to me to be correct. Then the Pos 24volt large starter wire has a smaller wire in it's harness with the tag that has 6 B tag and that was hooked to 24volt pos. That would seem to be correct. What wire is the 569? it would seem that my white splice wire should have been the 569 but like I said it was on a ground. Everything seemed to work ok on the truck but I just want too get it right as there have been many messed up thing happen to these MV's before we get them. Thanks.
