charlesmann
- 713
- 93
- Temple, Tx
Took my M936A2 out for a stroll and to finally use it for what i bought it. After several lite lifting jobs and repositionings, i went move in to position for my last lift job of the day. I disengaged the rear pto and went to put the case in high range, it wouldnt go, tried low, still no joy. I tried putting down and pressure while selecting 1-5 on the xmsn, still no joy. It took 4 attempts before the case went in to high range.
Any thoughts, places to inspect? Yes i had air (120psi) and i could hear the solenoid when i pushed button on the case shift lever.
Also, i have never had an issue with my xmsn indication but have also never used it to the extent i did yesterday, but the gage was showing pegging out on xmsn temp. Could it be a false indication as my eng temp gives most of the time?
when i get back to my tck in an hr, i will see when the temp reads while in building air. I will also hit it with my temp gun. Any specific location to check its temp?
My pmcs showed ample oil at both cold and operating temp.
