- 712
- 983
- 93
- Southern Minnesota
Ok, I've suddenly realized I have absolutely no idea how to use this tester to monitor the RPMs on the 6.5L diesel. I'd like to use it as a tach and verify the RPMs.
Does anyone have either a pointer (to a TM) or just in general how [and where] to attach this thing? All of the references I've found in the manual about the tach involve use the STE/ICE-R tool, but I've only got this one.
The manual in the tool talks generally how to attach it. I assume I need to attach the "transducer" to a fuel line, I'm assuming one of the lines to the injectors? or does it go elsewhere.. Then once attached, I'm unsure what to set the tool to in order to get a reasonable reading.
Thanks in advance for any sort of help you can give me.
