Wingnut13
- 562
- 93
- Strafford, NH
After my last ride I did a walk around as per standard. I heard an air leak from the passenger side cab air ride can. Today I decided to look into the issue and found the leak was from the top shock retention pin O-Ring. Once I had the unit it out it sounded faintly like a clunky hourglass, and once I had the unit apart I found the top shock bushing had deteriorated into rubber dust. I'm looking for a suitable substitute for the bushing and O-Rings. The shock eye ID is .875 (7/8") and the OD of the pin is .625 (5/8"). If I can locate a bushing and the correct O-Ring I'll post it up.
