- 673
- 894
- 93
- SW Va, Roanoke County
Did you use lube on the orings? I did one and didn’t feel like walking down to the other shop to get some. Leaked like a sieve. Needless to say, I went and got the lube.Yes, truck is chocked and on house air, just got to get the wife up in the seat and step on the brake to see which valve it is coming from.. I probably put a seal in backwards or something stupid
Oh yeah lube the sheets out of them seals with the grease that comes with the rebuild kitsDid you use lube on the orings? I did one and didn’t feel like walking down to the other shop to get some. Leaked like a sieve. Needless to say, I went and got the lube.
Quantity | Item Code | Description |
1 | AVP-31C1-24D | NITRA solenoid valve, 3-port (3-way), 2-position, N.C., single solenoid spring return, (2) 1/8in female NPT inlet(s), (1) 1/8in female NPT outlet(s), (1) vent hole exhaust(s), Cv=0.05, 24 VDC, 3.0W, 11mm DIN style wiring plug. |
Yes,M1078Man,
Would you be willing to give at parts list of what you bought to address your OLOD? I'm gonna go ahead and address the one on the M35A3.
Thanks,
SJ/JD
What app is that?Here is some screen shots before sun reaches panels, this is with the fridge/freezer running wide open and getting to 30/-1 in ECO mode
View attachment 846451View attachment 846452View attachment 846453
.\\MAIL CALL//
Recd these delineator
Search flee bay Military Vehicle Delineator M939 M923 M809 LMTV M35A2 M998 M151 MILITARY TRUCK
EXACTLY what I am looking to do.
Recently saw somewhere that had them offered as magnetics.
That way, you can have all the safety and attract as much attention as you need.
As a piece of magnetic material, if you need to sneak around in the woods they can easily be removed.
