JD4044M
- 1,003
- 93
- Okanogan, WA. 98840
.Yea well im fixing to fill this S,O,B, WITH FOAM ! Again today ( 3rd time ) i pull my 1 leaking steer tire fill up a spray bottle with dawn and a little water and start rolling the tire around the driveway a few inches at a time spaying the bead and where the rim bolts togeather not the first bubble so i put the valve stem on the bottom and submerged in thick soapy water with 80 lbs of air in the tire and just get really small foam around the big head going into tire so dried it all with brake clean and mixed up some jb weld and put it all the way around the bolt head last week i broke the tire down again tightened the valve stem inner nut and put silicone all in the whole before i put the stem back in the wheel and tightend the nut 5 days leaked 40 lbs back out so in the morning im going to air it back up and see if the jb weld helped anything ! We fill farm steer tires on the tractor sometimes with foam if were bush hogging rough thorn filled land i just wonder if it would work on these 395s ?
If he’ll work for a good home cooked meal and some cool, refreshing drink, send him over. I have 3 to demount & 1 to remount on my spare rim.
