Humvee gauge cluster
jim1131
36
Illinois
Trying to install a replacement gauge cluster on my 07 humvee 1165 with the electronic speedo but it came butchered from gov planet. The wires were cut and number tags are missing, does anyone have a wiring diagram for the cluster. Also which terminal would be the positive terminal on the back of each gauge?
mgFray
992
Southern Minnesota
couldnt find it for the gauges
Starts on page 1159 of the copy I have. The gauge part is snipped below. You'll have to figure out which wires are which since your tags are missing, but you should be able to trace them back to the control harness and other harnesses, it's just time consuming.
Action
1,561
East Tennessee
You can also use the parts manual in the wiring harness section to see what wires are in each branch of the harness, and to see what teminal should be on the end.
The maintenance TM will tell you and show in diagrams which number goes into which plug on the back of gauges.
