secondchancesurvival
- 6
- 3
- North Bend, OR
Hey guys this is my first post. I am building an M35a2 Crew Cab. I have the cabs ready to be grafted just need the time to do it. What I am also doing is installing the m54 steering pump to make my own power steering. While I have the steering pump, I might as well do a hydro boost brake system which I may run off an aux belt pump, I will have to see what pressures I have first. I'm swapping to 4 wheel disc, and the weight that the deuce is, is no more than what an F350 can haul, so I got a junk yard brake system for $50 bucks. The steering box I got came off a big rig and it was $50 also. I am budget building this but not in a shady way. I've built plenty of custom crawlers and such and sometimes buying an off the shelf kit is just too much money, if you have the knowledge to fabricate. I have a set of MRAP wheels and tires for it as well as an m105 trailer already. It should be kind of neat when done.
My question is does anyone have an M54 TM for that pump? I can't locate it and I need to see how many GPM that pump actually produces. Thanks for your help guys. I'm located on the Oregon Coast.
