- 1,117
- 1,054
- Perry, FL
I have two MEP803A's on a trailer with transfer switch. I do not have the generators grounded and was temporarily running a water pump. I switched to the #2 generator on the transfer switch to send power to the pump and when switching my thumb inadvertently made contact with the indicator bezel above the switch and lit me up. I check the voltage and was getting about 100 volts between the toggle handle and ground. Is the switch bad, or am I getting stray voltage from somewhere?
