Mep805a voltage reg kit.
Rikjames92
34
Ft.hood
Is this set new to you? Have you ever seen it run right?
It's new to me yeah. Another mechanic has worked on it here but no one knows anything about generators. I think I found the problem though. The mpu looks messed up it has a thin copper rats nest on the tip. Other MPUs I've dealt with would prevent the Gen set from starting so this is new to me.
Guyfang
23,831
Burgkunstadt, Germany
Apples and oranges. The gen set is a MEP-805A.
But the main gen, can be, I have seen it twice, I have heard about it many more times, a 400 hertz main gen. The problem being, that the -24P for the MEP-005A is wrong. It mixed up the NSN's between the 60 hertz and the 400 hertz. Thats what I meant.
Rikjames92
34
Ft.hood
I've never even had to replace main gen here. I usually get stuck with the ones that don't run.
Rikjames92
34
Ft.hood
IF the MPU is not the problem, take the rear panel off the gen set and on the right side of the main gen is a data plate. See what it says.
Still no luck. I checked all over the right side with my bore scope and didn't see any data plate. Its got 140 hours on the gauge and tge generator looks crusty and old.. no signs of the panel being ever pulled.the Frequency won't adjust and gauges m8, m9, m1, don't have readings. Of course the undervoltage light is on. Any ideas?
Guyfang
23,831
First I need to know if its a 60 hertz gen set, or 400. If it were 400 hertz, then all your Gages will not read right. And the contactor will not close.
kloppk
3,492
Pepperell, Massachusetts
Is that extremely important as it ran before with the old MPU and the tip was worn off
Yes it is.
Here is the TM adjustment Procedure...
ADJUSTMENT
1. Release control panel by turning two fasteners and lower control panel slowly.
2. Disconnect wire 147C from terminal 16 and wire 148C from terminal 17 of governor control unit (WP 0043,
Figure 1, Item 56).
3. Set multimeter for ohms and connect to ends of disconnected wires 147C and 148C. Multimeter should
indicate between 800 and 900 ohms.
4. Leave multimeter connected to wires 147C and 148C and set multimeter for AC volts.
5. Crank engine with DEAD CRANK switch (WP 0110, Figure 1, Item 11) and observe multimeter. Multimeter
indication should be between 2.0 and 3.0 VAC.
CAUTION
Do not adjust magnetic pickup (6) inward more than one eighth turn each time or damage to
magnetic pickup may result.
6. To adjust output voltage in Step 5 above, loosen locknut (6A) and turn magnetic pickup (6) in no more than
one-eighth turn at a time to increase or decrease output voltage. Tighten locknut (6A).
7. Repeat Steps 5 and 6 above until proper output voltage is achieved.
8. Remove multimeter and connect wires to governor control unit.
Rikjames92
34
Ft.hood
Yes it is.
ADJUSTMENT
Figure 1, Item 56).
CAUTION
Makes me wonder what the hell I was reading. Well it's almost quitting time. I'll jack with this some more later.
Rikjames92
34
Ft.hood
Yes it is.
ADJUSTMENT
Figure 1, Item 56).
CAUTION
Testing at the GCU I got 978ohms. A bit high I guess. VoltsAC is leaving me with .3-.4. The signal is not even close to correct. Thanks for keeping me honest. I'll attempt adjustment until I see a proper reading
Rikjames92
34
Ft.hood
Yes it is.
ADJUSTMENT
Figure 1, Item 56).
CAUTION
I'm having a hell of a time with this MPU. I've broke 2 now not including the one that was in it. The one I got in it right now I could only adjust to 1.1vac. While it's running I can measure 5.4vac across terminal 16/17. Is this where it's supposed to be?
