ppillard
- 33
- 18
- Evergreen, CO
Is there anyone in the Des Moines area that would sell me an alternator for my 1997 M1078, Cat 3116? I'm traveling thru and mine just crapped the bed.
@Ronmar Do you have a write up on this conversion or video?Well if you were not on the road, I would say this is a good time to convert to a commercial 24V 200A alt and a 24-12 converter/balancer(about1/3 what you are going to pay for another N1506 alt).
It might still be a good time if you can find a 24v alt and mount where you are at. You could still pull 12v out of the middle of the bank long enough to complete your trip, I would avoid driving that requires headlights though, and finish up the install later(asap) with a 24-12 balancer install when you are done traveling…
Good Luck!
Perhaps @wheelspinner @Suprman or @fuzzytoaster has one they can ship you.Is there anyone in the Des Moines area that would sell me an alternator for my 1997 M1078, Cat 3116? I'm traveling thru and mine just crapped the bed.
I've done it on a 915 series truck you just need 1 alternator, 1 24v to 12v equalizer (suprman has them) 1 24v solenoid and 1 12v solenoid. You wire the solenoids to come on when the key is switched on and it opens the circuit for the equalizer. You would just hook the 12 and 24v to the existing wires at the alternator area.@Ronmar Do you have a write up on this conversion or video?
I would like to see what that takes. I have a serpentine belt 3126.
I have a bunch but none tested yetPerhaps @wheelspinner @Suprman or @fuzzytoaster has one they can ship you.
If you try @Ronmar s conversion but don’t have time for the balancer, you could maybe get small charger to top of each batter at night. You will want the balanced eventually though.
Did you get going again? What was the fix?Is there anyone in the Des Moines area that would sell me an alternator for my 1997 M1078, Cat 3116? I'm traveling thru and mine just crapped the bed.
Not trying to hijack, but sense there has not been any traffic in a while, I thought it would be ok…..I've done it on a 915 series truck you just need 1 alternator, 1 24v to 12v equalizer (suprman has them) 1 24v solenoid and 1 12v solenoid. You wire the solenoids to come on when the key is switched on and it opens the circuit for the equalizer. You would just hook the 12 and 24v to the existing wires at the alternator area.
Yes it kills the output of the equalizer. Generally I put one on the 24v input and one on the 12v output this prevents any robbing from just the 12v side if the truck is offNot trying to hijack, but sense there has not been any traffic in a while, I thought it would be ok…..
What are the two solenoids for? To disconnect the equalizer positive lines so there is no vampire losses?
