Csm Davis
- 382
- 83
- Hattiesburg, Mississippi
Where does the two small wires on the starter go from the starter back up into the engine bay? I need to replace mine as they are falling apart.
Well...my 1008 and 9 both have just one little wire coming off of them...the other is the battery wire which is a 2 gauge wire...I just did the blazer wire the other day that connected to the solenoid...it goes up through the harness over the back of the engine to the fuse block under the brake master...inside to the starter relay under the dash...do you think it needs replaced entirely or just the last few feet?Where does the two small wires on the starter go from the starter back up into the engine bay? I need to replace mine as they are falling apart.
Probably replace entirely, it's 40 years old.Well...my 1008 and 9 both have just one little wire coming off of them...the other is the battery wire which is a 2 gauge wire...I just did the blazer wire the other day that connected to the solenoid...it goes up through the harness over the back of the engine to the fuse block under the brake master...inside to the starter relay under the dash...do you think it needs replaced entirely or just the last few feet?
I just looked at both of mine, truck and blazer...they have the same color wire going to the fuse block...I took a pic and pulled it with my knife so you can see which one it goes to the solenoid...I've pulled these ends out of the fuse box before to replace ends but not sure where to get those anymore...I don't think it would be that tough to find though! You think the other wire off the starter is the battery cable? I think you'll have to drop the starter to get to the terminal to take off that wire too...on a side note as well...look for a bracket that is bolted to the block and starter in the front...it supports it so the starter doesn't break off the block mount ear...there's 2 kinds depending on which starter you have.Probably replace entirely, it's 40 years old.
