Front wheel bearings
Adam Brice
Arizona
Hi guys,
So I was successful with changing my rear brakes, wheel cylinders, and bearings. I get to the front, had a fun time getting inner wheel bearing apart (in peices). See attached photo.
Anyhow, my new inner bearing seems just slightly too small, and doesn't quite want to slide onto the spindle.
Are the front bearings the same as the rears? I got my parts from big Mike's, and I included a pic of bearing part number as well. I don't think the number on the old bearing is still visible. Does anyone have a Timken part number? My new chinese one reads
NCB China 0920 3994
Also, is it possible that my spindle could just need some work?
runk
66
Houston, TX
Here is what my parts spreadsheet tells me -
(but I put it together several years ago, and you might want to verify the numbers in the parts TM)
parts, Wheel bearing, inner, front or rear3110-00-087-3930Timken 3994
parts, Wheel bearing, outer, front or rear3110-00-087-9881Timken 392
Adam Brice
Arizona
Hey! At least the 3994 is in there! Maybe I just need to clean up my spindle a bit more? Thank you sir.
20,465
Hi guys,
NCB China 0920 3994
Thank youView attachment 849443View attachment 849441View attachment 849442
My guess is that a little emery cloth will clean up the spindle. If you don't have that, course steel wool is the same with more effort. Don't get carried away. Buff a little, test fit it dry - and repeat.
It looks like your truck may have taken a few trips through a creek or two.
Adam Brice
Arizona
Yessir, it sure does. I do have Emery cloth, and plumbers sandscreen, so I'll do just that. Be a little work, but not too bad.
M35A2-AZ
412
Tonopah, AZ
I am thinking your inter seal is install backwards, If I remember right. That maybe why you got water in the baerings.
gringeltaube
Staff Member
2,641
Montevideo/Uruguay
That seal might be worn, but nothing else. (See my drawing which is to scale: it would be very difficult to install that seal backwards and have it stay put...)
Usually water gets into the hub, coming from the steering knuckle through the spindle, and caused by ripped boots.
M35A2-AZ
412
Tonopah, AZ
I went and found a seal, bearing, and race. The seal should rub on the race as the hub turns. If your seal has "outside" on it that should face the motor.000_0089.JPG000_0090.JPG000_0091.JPG
ldmack3
1,740
N. Central Idaho
Last pic look funky. With the hub and therefore the race off, what is that metal ring the rubber appears to be riding on? It is pretty gunked up.
Adam Brice
Arizona
