Vintage pics of M809s at Aberdeen Proving Ground
US6x4
2,332
Wenatchee, WA
These photos were discovered amongst the belongings of a former AM General salesman during his estate sale. They were packaged in a presentation binder in transparent page holders.
Most of the dates listed are August 1970. Enjoy!
If anyone knows of any videos of these tests I would love to see them!
reset2
86
Myersville MD
Wonder how the dash gauges and electrical components hold up to the river forwarding? Not to mention water getting into all the gearboxes. Not a concern when at war but as a hobbyist a lot of work to clean it up afterwards.
Thanks for posting pics are great.
Sent from my SM-G935V using Tapatalk
US6x4
2,332
Wenatchee, WA
Not sure about the electrical stuff but when outfitted with the deep water fording kit there are valves and lines that supply subtle air pressure to the axles, tranny, t-case, clutch housing, and maybe even the crank case. In theory the internal air pressure is greater than the external water pressure and that prevents water from intruding.
20,401
Definitely worthy of saving for historical purposes.
Sure would be neat to know more about the salesman too...
Superthermal
966
Utah, Murray, United States
Fording in an M813. With the solid non clutch fan on these things, I would think the engine fan would kiss the radiator as soon as a full suck of water was coming in from the front end. When we used to cross deep water with our jeeps we would actually get out and remove our rubber alternator fan belt to cross deep water and then put it back on on the far side. This was as a precaution after having a fan swim though my friends radiator. Any thoughts on this?
HDN
5,300
Finger Lakes Region, NY
How deep is the water you're going in? If greater than 30 inches, you should have the deep water fording kit installed per the TM.
Ajax MD
1,420
Mayo, MD
I'm not sure if even the fording kit includes anything that would solve this problem. My understanding is that the kit is mostly air pressure valves that put a slight positive pressure on the axles and drivetrain to keep the water out and of course, the snorkel gear. Give the increasing scarcity and expense of parts and the fact that you're not in a combat environment, I think that slipping the belt before a deep crossing is a simple and reasonable precaution to take.
