Had some time to kill this evening. I decided to check the basics, even though the previous owner said the IP had never been removed.
Since it’s easy to do a check and fairly quick, i decided to look at the IP timing to engine timing.
First I pulled the front valve cover to verify TDC on the correct stroke. Lined up the correct timing mark on the balancer and checked to make sure cylinder #1 int/ext valves were closed.
Next I removed the timing cover to look into the timing window on the IP itself. Verified timing mark is at pointer.
Lastly, even though it is not a true “timing” mark, I looked at the HH’s gear inside the shutoff cover. The red tooth is one tooth to the rear of the pointer, which from what I’ve read and am told is correct, because technically that red tooth ONLY lines up when removal is needed.
Also removed the delivery valve and spring, it moved freely and I also sprayed out the passages.
Good news, that stuff is all good
Unless for some odd reason after all these tries, I haven’t successfully engaged into the plunger sleeve/shutoff block with the little nipple.
