- 488
- 366
- 63
- California
Found them! That was great info! Thank you! Definitely there is something going on with the fuel filter, the moment I removed the two bolts and tried to move it around, it started to leak from the bottom, and it goes to the theory that air is getting into the fuel system.There are 2 bolts inside by the end of ebrake handle(when down). Those hold the fuel filter to firewall. It is easier to get the canister out if you remove the 2 hoses at top, from inside the truck.
I don't know if the pump is supposed to come out from the top, but there is where I pulled it from, between the engine harness, the ground cable that goes right above it, the oil check stick and the purple acceleration cable that constantly gets in the way, but it's out! I hope I can put it back in
And there is a cut in the bottom tubing, which I will replace.
Does anyone know where the 4 wire connector should plug in?
