Yes it just seems to take too long to change up & does rev quite a bit.Your post is lacking quite a bit of information. If slow to change up means it is waiting to make the shift till redline you probably have a rotted out vacuum line to the modulator.
Check the vacuum line coming out of the plastic box attached to the side of the injection pump. That line goes to a metal tube under the intake manifold then down to the modulator on the side of the transmission with a little short piece of rubber in between periods probably rotted out somewhere.Yes it just seems to take too long to change up & does rev quite a bit.
Give him a break...he's from the UK...they say stuff like fish n chips too...I'm sure if you said soda up the midwest of the US people would correct you and say POP!! lol just giving you a hard time.The word for that is, "shift".
Vacuum lines. Cheap and easy to replace. First place to look.
Oh, my bad. I didn't realize he suffers from that tragic handicap. Those Brits are all messed up. They think chips are crisps, and cookies are biscuits, and all kinds of crazy stuff.Give him a break...he's from the UK...they say stuff like fish n chips too...I'm sure if you said soda up the midwest of the US people would correct you and say POP!! lol just giving you a hard time.
And be gentle with the plastic-rubber valve Tee....
Yes thats low...I do ask though if the line going to the trans is ok as if it is leaking the vacuum will be low...unless you have it hooked not to the tee but on the actual pump which is what you wrote but just want to make sure.Vacuum gauge straight onto pump, guessing this is too low. New pump ?View attachment 851799
Yes, straight onto pump.Yes thats low...I do ask though if the line going to the trans is ok as if it is leaking the vacuum will be low...unless you have it hooked not to the tee but on the actual pump which is what you wrote but just want to make sure.
looks like the pump has let the smoke out...can you get one out your way?Yes, straight onto pump.
One of our parts suppliers can get one shipped in, in about 2 weeks, I normally use rockauto but they're out of stocklooks like the pump has let the smoke out...can you get one out your way?
Amazon vacuum pump pod replacement 90-1008 $87.34 read the reviews it works for the 6.2 cucv diesels.maybe you can buy pump here if someone in US is willing to send core to Hilbilly?
GM Diesel Vacuum Pump
Hillbilly Wizard sells the hard-to-find parts you need to build your project vehicle!www.hillbillywizard.com
Or here:
6.2 Diesel Vacuum Pump POD Replacement | Accurate Diesel
Get your truck back up and running with this 6.2 diesel vacuum pump pod. This brand-new OEM component replaces the upper pod part of your GM's pump.www.accuratediesel.com
Thanks, found one on U.S ebay. On its way over now.Amazon vacuum pump pod replacement 90-1008 $87.34 read the reviews it works for the 6.2 cucv diesels.
