3up
- 97
- 28
- nevada boulder city
Thanks for the info it sounds like an exhaust leak on the exhaust manifold but I don't see soot trail anywhere. Will check the muffler
Check from turbo, back at every connection point.Thanks for the info it sounds like an exhaust leak on the exhaust manifold but I don't see soot trail anywhere. Will check the muffler
Run the part number from the 24P and probably be cheaper than a cummins dealer.Made it home. Ordered new alt. Where to get exhaust manifold gaskets? Or any parts for theses trucks?
How do i know what motor i have and what is 24P?Run the part number from the 24P and probably be cheaper than a cummins dealer.
Most parts are available from napa or other truck parts places with the applicable part number from the spreadsheet
.How do i know what motor i have and what is 24P?
Do you have an A1 or A2 series? A2 correct? You should have the 8.3, unless someone changed it out for something else. You’ll want to download the technical manual as mullaney mentioned and start going through them.How do i know what motor i have and what is 24P?
Thank you reading nowIt's an A2 from the picture you posted which is an 8.3 6cta those A2/ engine specific numbers are at the bottom of the spreadsheet
