There is "knowing" and there is "doing"...we'll see if I can get the two to meet up.Good Job. I see you know about sliding it back. Good Luck.
@cucvrus Just making sure you are saying you reuse the Flexplate to torque converter bolts and not the Flexplate to crankshaft mounting bolts...or are you talking about Flexplate to crankshaft mount bolts (or reusing both)?Put lock tight on the torque converter bolts and reuse them. I have new ones but have used thousands of them over. They are NOT torque to yield stretch bolts. I have in the past sent transmissions out for rebuilding and they were returned with SAE thread in the torque converter or vise versa. I just dug thru my used bolts and found the correct short bolts and used them. I have not had any failures in 40 + years of doing so. Now on the other hand I do NOT reuse head bolts. I don't use studs on heads either. I have removed more transmissions then I could ever hope to install and I use all the hardware for other vehicles or scrap it. I have thrown away many 5 gallon buckets of bolts. I only keep pristine hardware. Good Luck. Let's get in done Safely.
That is a wish doll. You have to rub his head at the same time asking out loud for your wish to be granted. Try it, you won't regret it.
Sweet!That is a wish doll. You have to rub his head at the same time asking out loud for your wish to be granted. Try it, you won't regret it.
I have the same seat color...I need to find foam and the lower cover as well.Anyone know if there is a place to get seat vinyl that matches this?
shhh...for real though...does anyone know a kid they don't like so I can get rid of this creepy ass doll I found under the seat? It won't stop staring at me.
I've seen the Talking Tina episode of the Twilight Zone, I know how that shit works out. So rather than trying to throw it away, I'll make it someone else's problem like the PO of this vehicle clearly did to me...
