ramdough
- 1,729
- Austin, Texas
Truck:
1999 m1083 A1 3126 serpentine re-certified in 2009
Symptoms:
On start up if left in low idle, the engine surges in a rhythmic way. In high idle I do not notice it. In gear, the truck lunges with each surge.
Once the truck is really warmed up (30 minute drive), no more surges.
What I have done so far:
Assumed air leak in fuel system. I have new fuel hoses. I checked to make sure the ends were tight. I have a new ish fuel filter (500 miles on it). I checked the bowl for cracks or leaks. I pressed the primer button to see if it leaked or got hard once it pressurized (with engine off). I have not found any obvious issues.
Before I replace the filter base with primer button…. Any suggestions? I hate throwing parts at problems.
I also thought of buying injector lubricant additive for the fuel tank (friend recommended).
Thanks in advance for any suggestions!
Sent from my iPhone using Tapatalk on
Symptoms:
