- 6,425
- 4,987
- Ft. Lauderdale, Florida
To confirm and reiterate what I did…
I never took that arm and shaft apart, definitely the previous owner, I will message him today. I meant I pulled out the fuel shut off so I could replace the small oringGlad you figured it out because too much thinking was making my brain hurt.
So when you had the fuel control unit assembly out you disassembled it?
Yea the correct orientation is in the TM.
His response…I never took that arm and shaft apart, definitely the previous owner, I will message him today. I meant I pulled out the fuel shut off so I could replace the small oring
