Parasitic battery draw
Tow4
646
Orlando, FL
I tested both alternators - good voltage at idle. After the 40 mile trip, I did start it (to be sure it would), but turned it off almost immediately. Might the, hot, starter (if not at 100%) have sucked the batteries down? Is there anyway for the starter to cause/contribute to the drawn down when the vehicle is not running?
What were the good voltages?
Rrent
142
Texas
I just tested with my Harbor Freight battery load tester. The #1 was rebuilt 3-4 months ago, #2 rebuilt 2-3 days ago. The number one seems to move the needle after the truck has been running for a while. Hopefully unrelated (but I didn’t think to notice the timing), I did get the high idle/ip timing advance set up and can tell when the truck warms up enough for it to “kick-off”.04C91A8D-65E2-4DF6-BC55-A77FA4E0039D.jpeg96594F6E-E7F0-4560-997C-FA96969FE0FC.jpeg
frank8003
4,985
Ft. Lauderdale, Florida
I've got a 24v system in my Bass Boat, and I have a Genius Batter Charger that charges all 3 batteries (starting battery and 24V (two 12s) trolling batteries) on a trickle charge. Probably one of the best purchases I made for that system, because those batteries aren't cheap., and that Genius battery charger can bring some batteries back from the dead.
I may do the same thing on this truck if I'm going to be letting it sit for long periods.
that thing is
Fully submersible.
and is 300 bucks.
Squibbly
1,039
Alabama
that thing is
Fully submersible.
and is 300 bucks.
I paid 170 on Amazon. Not sure why someone would charge (or pay) double.
Amazon.com: NOCO Genius GENM3, 3-Bank, 12-Amp (4-Amp Per Bank) Fully-Automatic Smart Marine Charger, 12V Onboard Battery Charger And Battery Maintainer : Sports & Outdoors
Squibbly
1,039
Alabama
I was looking at that exact one - kinda pricey for my “truck budget”, but I’ll probable get it. Have you had a chance to hook yours up? I would love a real world review before I spend the $’s.
I haven't had a chance to hook it up yet. I'll give a review once I've had a chance to use it.
My brother seems to like it, and he generally knows what's up with these things.
I PMd you on the other stuff.
Tow4
646
Orlando, FL
I just tested with my Harbor Freight battery load tester. The #1 was rebuilt 3-4 months ago, #2 rebuilt 2-3 days ago. The number one seems to move the needle after the truck has been running for a while. Hopefully unrelated (but I didn’t think to notice the timing), I did get the high idle/ip timing advance set up and can tell when the truck warms up enough for it to “kick-off”.View attachment 851530View attachment 851531
Alternator #2 is 14.8 which is the regulator set point so it's ok. Alternator #1 is 13.8 and that is low. If the battery is ok and just discharged it should eventually come up to about 14.8. If it doesn't come up to 14.8 or within a couple of tenth's of a volt about 5 minutes after starting the engine, I would charge the battery over night and then load test it. If the battery is ok then there's a problem in the alternator or truck wiring.
Rrent
142
Texas
It does increase with run time - I’ll keep checking. Fingers crossed it’s not wiring.
