Why are my starter bolts coming loose??
nyoffroad
682
Rochester NY
" It actually cracked the inspection cover on mine as well. Apparently these starters have a lot of torque. I have been told if you don't take care of it, it can crack the block. "
Yes it can, it can and will break the outer 'ear' off the block where the outer starter bolt threads into. and that is a lot of fun trying to fix!
Sganderson
53
South Carolina
Just for fun, how would you fix that? I kind of assumed once that happened you’re up the creek on that block.
