- 16,413
- 23,349
- Burgkunstadt, Germany
Its called PMCS. Preventive Maintenance Checks and Services.
White smoke is usually water in the fuel system from condensation. I would check the tank cap seal.
We use diesel additive here in Kansas, that reduces the white smoke during startup.
It's in a heated garage. it's not water
btw. where does your exhaust go? Probably not in your heated garage. The condensation occurs after the generator ran to operating temperature and is shutoff.It's in a heated garage. it's not water and it's only one exhaust pipe that is smoking and pops 3 or 4 times for two minutes. i am leaning towards a burnt exhaust valve.
Thank you for your help Ray , i am all setFYI, sent you a text earlier today to see if we can make arrangements to look at your machine. Let me know if you didn't receive it.
