- 820
- 220
- 43
Hey all, searched on here and found bit and pieces of info, mostly people with actual transmission problems and not so much about the indicator. My shift indicator has been off at least 1 "gear" for sometime now. I tried adjusting the "string" back sometime ago, but the indicator would soon return to its "off" position. I've just clicked through R, N, then into D. But sometimes I'll start driving and question if I'm in 2 instead. Further if someone else drives the truck they're always confused as to what is going on.
In any case, I was thinking about buying a new indicator from LMC, actually I think I may have replaced this once before back about 10 years ago. In either case, LMC have two different one's listed (well 3 actually but I know a CUCV with the original TH400 transmission doesn't have OD). The first one is a # 32-7238 (1979-83) and the other is a # 32-7240 (1984-87). I've got a 1986 M1008 so I would guess it is the second one for the year listed... but I've read in the past that even though this was built in '86, but because it is a military truck it is built to the specs of the '83 and sometimes this affects parts.... and of course these two have to basically be border line, and LMC only shows one photo for both of these. So anyone know which would be correct? Or better yet, any know of a way to fix the indicator to actually show the correct gear?
Also, I finally had some time today to install my new LED headlights that I got from LMC back 6 months ago probably. Went to install the new adjusters and the adjustment plastic "clip" that the screw goes into, would NOT lock into the slot in the metal backer behind the headlight. I broke two of them trying to get them to lock in. As no matter what I did, the two sides of the clip that are supposed to spread open once through the slot, would never pull all the way through without just breaking off. It was as if they were to long to actually pull through the hole. And of course these were dorman... I hate dorman products, used to work at a parts store and they carried dorman for all kinds of stuff like this and in my opinion all of it was garbage. Either it doesn't fit, its not to spec, or it just breaks. I think these are all 3.
Anyway, I've got to order some parking light lenses from LMC anyway, as the mounts on these old one's are broke. Tried to repair them, but it'll only hold so long. Also don't want any NOS stuff, as its just as old and brittle. In any case, since I'm ordering those I was going to order some new adjusters from LMC too. I am HOPING that what they sell are ACTUAL OEM or equivalent and surely not this dorman junk. I doubt the clips were originally plastic were they? I would be betting they were metal.
Don't mean to run on... but where does the "headlight spring" mount to??? The springs on both headlights were just dangling when I took the old lights out. All the part diagrams I've found shows the spring, but doesn't actually show where it goes. The headlight metal "bucket" mount doesn't seem to have any obvious hole or "arm" for the spring to attach to. Even if it did the spring is so short, how do you clip it on before installing the headlight all the way... or how do you get your hand in there from the back to do so after the headlight is installed??
Anyway, guess I won't be driving my truck until I can get new adjusters. That was the whole reason I bought these "replacement" one's to begin with, as I wanted to do the job without having my truck down waiting on parts...... oh well, usually how it goes.
Hope everyone is having a better day, thanks in advance for any input
