- 1,813
- 1,513
- Orlando, FL
You can save the gear oil and reuse it if it is clear and clean. Otherwise, front 2 gal, rear maybe 2 1/2 gal. front no need to remove big hub nut in front so no oil loss. Rear must remove nut so very small loss but hub oil in rear comes from diff oil so it will refill itself. You will need some gear oil RTV. No other parts needed, just clean the kingpin seals and grease the kingpins when done.
Front Axle Differential: SAE 75-W90, 9.5 qt |
Rear Axle Differential: SAE 75-W90, 18.05 qt |
Front Axle Planetary Hubs: SAE 75-W90, 11-13 fl oz (each) |
The total is almost 7 gallons. Mine took every bit of that.
