M322 Tail Light Question
Steelreaper80
96
Indianapolis IN
I had LED taillights on the M322 and they over time went out little by little so I swapped to standard tail lights. The lights worked fine for a while then I had no brake lights. Everything else would work. I installed 2 new tail lights on the trailer and now everything works except when you turn on the left turn signal, the passenger side light shuts off or when you step on the brake the passenger side shuts off. I have running lights on both and turn signals on both. I cleaned the trailer and truck connectors and checked the light connections. Any idea? Thanks guys!
simp5782
Feo, Fuerte y Formal
9,339
Mason, TN
Ground. Run a new one from tail lights under the rear if the trailer
Regular lights tend to blow out from the amount of bouncing those trailers do.
