Steel Soldiers MV of the month 2021 - December VOTE HERE!
4,817
1. microjeep
2. Third From Texas
3. fuzzytoaster
4. simp5782
5. Migginsbros
fuzzytoaster
3,132
Fort Worth, Texas
tl:dr: see below
Story:
The MK4 has been on an adventure since her rebuild in 2012. Somehow she ended up in a penal colony in Indiana that was staffed by prisoners on good will doing forestry work. She was the typical: no start, no run, hydraulic parts missing, and no keys. Murphy being present as always meant she was in the back of the yard with no real way to get out and no loading assistance. This too was only another step in her adventure.
For those not in the know, an MK4 is heavy for a "4,000 lb forklift" and required both M10As to lift her safely. This meme comes to mind..
My gut told me she was a diamond in the rough so I bought her but now she was here in my yard DOA. In my eyes, she was new (to me) and later discovered the latest in MK4 models rebuilt for the military with Cummins 4BT and a total reset - schweet! What I also found was the right main pivoting hydraulic cylinder was MIA and assumed to be salvaged for other units. I got the NSN and crossed it over to Case and gave my local dealer a call for availability which there were 3 left in national stock inventory.. at $6017.00 each before freight and tax . Hahaha.. no :cookoo: . It was the first time I've ever laughed someone off the phone. Unfortunately no one makes a cylinder the stroke and diameter of this machine so I took the cylinder off the other side and had it cloned and rebuilt for $780. (suck it Case). After a hose, remounting a tire, and batteries she fired up on the first crank. I was blessed by the MV gods for a full tank of JP8 which kept the crud out of the tank. I later replaced the 3 way switch and all the lights worked. She's 100% functional and to spec. Of all things green to be fully operational a MHE (Material Handling Equipment) was not the one I would expect.
lt;dr
It's an amazingly simple yet robust machine. It's small enough you can trailer it yet large enough to flat tow 5 tons. It's quick enough to give my M-Gator a run for it's money yet nimble enough to get in tight spaces. The torque is impressive and it will not get stuck. I've gotten it up on 3 wheels climbing over a stump and wiggled through Texas silt/clay with no worries. It's an ideal engine hoist and trailer jack that will save your back. It has always started and been a faithful unit to me and I consider this a fitting second life for this unit. Who knows where it went or what it saw since it was built in 1982 but in the true essence of a steel soldier it was refit and ready for duty. In this case it's the main unit in my moonpool and helping other MV's get back into action. Vote MK4 - gift giver for the holiday month!
simp5782
Feo, Fuerte y Formal
9,384
Mason, TN
@simp5782 : @IRIS_Always wants to vote for you, but needs more info on your truck! To quote her "I don't even know what it is!!!"
It's a 2008 rebuild M920. Big cam cummins, 13 speed RTOO. 2 spd Oshkosh 55000 transfer case. Lockers, twin 55000lb winches from a HET. Air conditioning.
Pretty reliable rig. 1200mi in a day if it needs to. But very heavy for anything offroad but can get itself out of trouble.
dmetalmiki
2,028
London England
tl:dr: see below
Story:
View attachment 853431View attachment 853430
View attachment 853433View attachment 853434
View attachment 853428View attachment 853427
lt;dr
View attachment 853426View attachment 853429
I so like HUGE trucks..(N' traileres..)
I had to choose between Simp and your efforts.
You.. seem to havere claimed restored and devoted expertise in bringing the fork truck back in extstance..I am having another look the outfit of Simp's..As that needs HUGE amounts of expertise skill and knowledge.
dmetalmiki
2,028
London England
Pretty reliable rig. 1200mi in a day if it needs to. But very heavy for anything off road but can get itself out of trouble.
I so wanted to vote for this outfit..Hard choice..between the obviouse expertise of both Simp and and Fuzzy..Hard to decide, Wishing we had TWO votes..
