- 7,287
- 10,221
- Papalote, TX
It is almost impossible to break tempered glass even with a heavy hammer, funniest thing I ever saw was a guy going to break into a car and the brick bouncing off the glass and knocking him out!You can take your shirt off and wrap around your hand to break tempered glass. The tempering makes it break into lots and lots of tiny pieces.
if you try to get out through a laminated windshield, you will likely have to knock the entire window out. Laminated sticks together when broken.
You need something sharp and heavy and you need to get into one of the corners. as stated before an automatic center punch might work as it compounds the force
