TheGreatMidwest
- 0
- 0
- the middle of Ohio
Late question to this thread sir! In your installations did you ever come across studs that were too short to go through the plate and battery cover? My commander kit seat studs arent long enough and i'm thinking it was meant for the back maybe? I'd rather not weld new bolts as i just got this kit.I can get them for you tomorrow...I have done about 20 and its not hard. Have primer and paint ready to cover the bare aluminum when you remove the old drivers base.
One seat has longer studs than the other, try the other seatLate question to this thread sir! In your installations did you ever come across studs that were too short to go through the plate and battery cover? My commander kit seat studs arent long enough and i'm thinking it was meant for the back maybe? I'd rather not weld new bolts as i just got this kit.
the other seat is the driver seat, it has the big black base attached already, (came that way) are you saying I should un-attach it and try that one on the passenger side? Thanks!!One seat has longer studs than the other, try the other seat
Well you can measure the studs, if it was a new boxed seat retrofit kit one of the seats should have longer studs, if that is the one you are trying to install on the Commanders side then something else is wrong.the other seat is the driver seat, it has the big black base attached already, (came that way) are you saying I should un-attach it and try that one on the passenger side? Thanks!!
The Commanders studs measure about 1 1/4" the driver studs are about 3/4"the other seat is the driver seat, it has the big black base attached already, (came that way) are you saying I should un-attach it and try that one on the passenger side? Thanks!!
thanks for all the info, I removed the other seat from the base and both seats have the exact same stud length and model numbers on the seats so idk. Basically the back studs don't reach through at all. Had no idea there were different stud lengths on these.The Commanders studs measure about 1 1/4" the driver studs are about 3/4"
this is how both fit on the plate, no room for the battery cover on the back with this stud height, they barely poke through not enough to get a thread on. Am I doing something wrong? Holes were pre drilled in battery cover already.Those look long enough, if they are 1 1/4" they should work, the "new" seat base is nesting flush with the old battery cover yes?
maybe some kits just had two "Commander" seats, probably having the longer studs would not hurt anything and it would simplify things a little
back the camera out, it almost looks like the plate is backwards let me run back to the shop and see if I can find a plate.
1" and 3/4" on both lol looks like I got bamboozled!Again measure the studs...
