.I am new at this, but I bought a 804b generator and have some questions. I have an under voltage light on and the ac interrupter light and the battle short stay on. Any help is appreciated, just please don't get too technical, or go slowly with me.
I adjusted the hertz to 50 and the volts to 204, so it shows power, but I checked the 120 outlet and have no power..
Welcome to the Outfit!
There are quite a few really sharp guys here who work on and repair generators. Several of them offer repair parts too. Troubleshooting guides are in the Technical Manuals (TM's) and it might help if you have those free books downloaded to your computer or phone or tablet.
Undervoltage light... Is the machine making power?
The hertz will adjust up and down, as well as the voltage. The s12 is in the 50 hertz position. I have tried to reset the GFI. I have down loaded the TM, but have not seen this unit run correctly.I have an under voltage light on and the ac interrupter light and the battle short stay on. (All the time? Or as soon as you place the S1, (start switch) in the run position?) Or do they come on when you let the S1 go, during start up?
I adjusted the hertz to 50, (will the hertz go higher?) and the volts to 204, (Will volts go higher?) so it shows power, but I checked the 120 outlet and have no power. (Have you reset the GFI, AND the J1, (120 volt outlet?) The reset for the J1 is on the inside of the control panel, on the side of the GFI)
Is the S12, (50/60 hertz switch) in the proper position?
Have you ever seen this gen set run correctly?
Have you down loaded the TM?
They have not changed the electrical requirements, yet. I had ran it on 60 hertz,but wanted to check out the operations on 50hertz. They both show show that they are working, but still show under voltage.Why are you running in 50 Hertz? I have not lived in the States for a very long time. Has there been a change from 60 Hertz, to 50 Hertz?
Sorry,I have been down for a while, with doctors. I have checked, and there is no power at J-1 or at TB4-15. K5-1 shows 124 volts. And I want to say thank you for your help.Put the set in 60 hertz, and leave it there.
If you have no ACV at the J1, go to TB4-15 and K5-1. Measure there for 120 VAC. What you got?
Measure between TB4-15 and K5-1. You should get 120 volts AC. If you do, then you need to reset the circuit breaker CB3. Or replace it. That's why I posted the schematic above.Sorry,I have been down for a while, with doctors. I have checked, and there is no power at J-1 or at TB4-15. K5-1 shows 124 volts. And I want to say thank you for your help.
Back from holidays, I hope you had a good Christmas. I checked voltage at TB4-15 and K5-1 it shows 128 volts, and CB3 will not reset. I noticed the hertz seems to fluctuates,a little. Maybe the gauge?Measure between TB4-15 and K5-1. You should get 120 volts AC. If you do, then you need to reset the circuit breaker CB3. Or replace it. That's why I posted the schematic above.
Back from holidays, I hope you had a good Christmas. I checked voltage at TB4-15 and K5-1 it shows 128 volts, and CB3 will not reset. (Then you need a new CB3) I noticed the hertz seems to fluctuates,a little. Maybe the gauge?
(What kind of meter are you using? Digital or analog? How much is "a little?)
Can you post a film of the gauge during start up?It is the original analog gauge and seems to fluctuate 5 to 10 hertz when it is first started, and needle sticks.
I don't know how to do that, and I went back out and checked, it fluctuates from about 58.5 and 60.1Can you post a film of the gauge during start up?
Withou fuse.I would look up the NSN and plug it into Ebay. If no joy there, post a want add in the forum. Someone may have a take out on hand. Is yours with, or without in line fuse.
