Hey all,
I want to inspect the rear and intermediate brakes for leaks and check the pad wear. I haven't done it since I've owned the truck. (I did service the steering axle)
I'm reading the -20 TM. I've ordered the little cork gaskets (but I'm also amenable to using a modern sealant).
Page 9-18 is a bit unclear. It states that you must use a hammer and drift to remove the bearing cups (races). If I'm only re-packing the bearings, I do NOT need to remove the races, right?
In terms of consumables, I need the hub flange gaskets, cork plugs, inner grease seal, and outer grease seal. Anything else? On page 9-17, item #13 is listed as a "wiper." Is this a consumable or can I reuse it? I have a fresh brake cylinder on hand in case I find a weeper.
The truck stops very well, and smoothly. I see no signs of gear oil or brake fluid leaking out on any of the intermediate or rear wheels. I have added a tiny bit of brake fluid to top off the master cylinder once in the last 2-3 years. When I serviced the steering axle I was amazed at how clean everything was and the brake shoes were new. The wheel bearings had grease but it was thin and runny so I re-packed them. I suspect that the rear and intermediates will be in similar condition. This is mainly a preventative exercise.
I wish I had a duals jack. That would make life easier.
