Recirculating Coolant Heater?
antennaclimber
1,042
State College, PA
We use them on our larger diesel fueled generators at tower sites. They do work well on keeping the engine coolant in a warm to hot temperature range.
Easier starts and the engine is ready to take the full electrical load when the transfer switch connects the building load to the generator.
Only ever had one burn out after nearly 20 years of continuous use.
I have not used on on a CUCV.
Tailwheel
60
Charlotte, NC
Can’t help you as I’ve never used one of those but there might be some good info at ExpeditionPortal.com.
Those folks build some wild overland expedition vehicles and often used multiple types of coolant heaters and exchangers in various different ways.
2INSANE
847
Belgrade, Montana
Let’s talk about this. So the outlet would be a t fitting on one of the heater core hoses and the inlet would be somewhere on the lower end of the block…. So where is the best place on the lower end of the block to tap into?
Perhaps a freeze plug on driver side with a bung welded to it?
Skinny
492
Portsmouth, NH
I see a lot of these on the standby units I work on, especially the Generac and Winco units. Handful of them I've replaced due to leaks. One burned out because a freeze plug leaked draining the coolant, then the heater went full on meltdown...
Other then that pretty good. Probably can't find one better for the money.
2INSANE
847
Belgrade, Montana
If no one has done one of these recirculating coolant heaters on their CUCV, I’ll do one and do a write up on it! I think this would be a much better solution to warming the motor and radiator at the same time with only one unit.
20,467
It definitely would be a useful tool in a seriously cold environment.
Would think it would be a BIG PLUS to add valves on the block (inlet and outlet) to shut it down if a hose broke or the plastic heater cracked. Moving water seems like a heck of a plan to me too!
royalflush55
547
Reydon, OK
Look at a Kat's Heaters Thermostatically controlled tank heater # KH13150. 120 volt- 1500 watt.
These have been used for a long time on tractors and trucks.
ssdvc
640
CT
I thought there was an older thread on this and that it couldn't be done because of the way our coolant is routed. I have used these types of heaters on my older diesel VW's with really good results and would love to put one on my 1009. I hope someone finds a way.
2INSANE
847
Belgrade, Montana
I have a cold advance switch, radiator needs swapped and thermostat needs done here soon. Will have to drain the coolant. Will be a perfect time to experiment and report back how it works.
