GreyEnvy
- 5
- 3
- North Mississippi
Picking up M1078 A1 (15k serial, so early A1) from GSA, it had dead batteries and had to be boosted to start. The volt meter bounced from one end to the other and the transmission would only engage for a few seconds at a time.
I pulled the four dead 6TL and replaced with 2 group 31 using the usual schematic from the forums. At this point it cranked right up and the transmission seemed to be working.
I let it high idle 15 minutes while doing other things, then turned it off and now it won't start. It turns over plenty fast but makes zero effort to fire. Not even a hint.
I feel like there is some sort of start inhibit going on.
I checked all the circuit breakers, swapped a few around, swapped a few relays around (not mixing up the 12V and 24V), no change.
The yard guy said they won't run on 2 batteries because the computer senses there isn't 4 present. But I know most people here are running 2 batteries.
I can't get the TM to download on my tablet.
Ideas?
Ideas?
