- 2,651
- 2,141
- Sunman Indiana
Whats you’re thoughts on the hydraulic fan, I assume they are actually hydraulic driven, or just actuated?
Hydraulic driven with a 3 stage speed manifold. Each manifold port opens and closes within a temperature range and bypasses fluid when the temp is below a set point so it basically has off,low medium highWhats you’re thoughts on the hydraulic fan, I assume they are actually hydraulic driven, or just actuated?
LOL what are you trying to say to the 4 wheeler at 8.01 in the video ? This ride is nice to keep me from having cabin fever i got to take a trip and never left my desk ! You should make more of these then this winter to make me glad im home!Not too much to report. Logged some miles. Only 3k last week. Went out west and back.
I've got a cab deterioration problem I need to address for the driver's front mount. I was able to use a longer bolt to go thru from the upper cab floor to reach the bottom. I am planning on an aluminum channel mount using All thread as a clamp. Then foam fill the inside of the cab where the issues are to reinforce it.
Got a new seat that was a end of the year special $1500 marked down to $700. Has a heater and cooling system in it.
I also finally got a chance to swap on the dual V type belt to keep the pesky alternator belts from stretching so easy. Part # 2/4591PB for those interested.
Had an oil leak on the plug on the block by the oil pump. Uses a copper gasket. Stupid design as you can't even get a 1/2" Allen head to it. It was fun to get out. Weird 7/8-18 thread size.
Fixed an oil leak on the front tandem pump and replaced the hoses with steel jacket.
Luckily I was able to spray it all with degreaser before I drove thru a monsoon last weekend. Was nice and clean to work on.
Future plans when I have time may be a hydraulic engine fan from the PLS units. And an HT4C turbo.
It doss pull pretty good they the Virgin River Gorge in Utah. Sitting at around 63,000lbs. Was nice and scenic.
Is it still 80 mph in stretches between Van horn and San Antone ?They get me on the downhills but she will run 82 with em in West Texas.
He was pacing me behind me when I hit my signal he then pulled up along even with the trailer making me get out of the gas on that weiner wagon in frontLOL what are you trying to say to the 4 wheeler at 8.01 in the video ? This ride is nice to keep me from having cabin fever i got to take a trip and never left my desk ! You should make more of these then this winter to make me glad im home!
LMAO ya gota love little pricks like that ! We used to give em a free trip to blue lagoon ! and hit the dump switch on the black water tank then when they came on by those wipers were just workin thier ass off and they had no idea what had happen but we had to hope to run in rain after that to wash the smell out from under us !He was pacing me behind me when I hit my signal he then pulled up along even with the trailer making me get out of the gas on that weiner wagon in front
.LMAO ya gota love little pricks like that ! We used to give em a free trip to blue lagoon ! and hit the dump switch on the black water tank then when they came on by those wipers were just workin thier ass off and they had no idea what had happen but we had to hope to run in rain after that to wash the smell out from under us !
Funny.
Have to add a second pipe further to the back of the bus...
That way "the goodie" could be delivered with less smell under the wagon.
Long years ago... Used to use window washer pumps plumbed to shoot right or left using vinegar would "help" people who needed it at a stoplight.
Good to have confirmed. I’m building a container hauler out of a log trailer (off-road suspension) and came to that conclusion… The dual axis hitch (plus the 46” tires) put me around the same height on the 5 ton. I’ll be nervous under my first bridge anyway.Just a note that you can move a standard height 40ft container behind a 916/920 but not a High Cube.
9ft 6 high cube. Plus 65in from ground to the bottom of the high cube at the kingpin. Total of 179in.
Standard container would be a shy under 14'
We ran 365/70/22.5 on steer and boogies and some of the H models ran 455/55/r22.5 on 14 in wheels on 19,000 lb rated steer axle same spots all were michelins but never got very good wear out of them .New Sumitomo steer tires. 445 65 22.5s ST520s.
Was wanting some continental HCS's but supply is low so I settled for these for now.
Only reason to settle for them was the price. They were $626ea shipped in. And that included the $42 FET. I figured it was the best price since they are normally $950-$1100.
Had a cracked timing cover from a loose bolt so I got that fixed and sealed up. Replaced the front tandem pinion seal...again. dunno why it went to leaking so I upgraded to a different seal type.
Had a broke turbo stud that was leaking boost. I ended up removing them all, retaping and replaced them all. Was going to swap my other turbo over to an HT4C but figured I would wait.
Ended up having to reattach a cable with some cable clamps. Was pulling a 966 track loader a few weeks ago with both cables double lined and ended up snapping the end socket. It's a bad day when you start snapping cables and 3/4" wrecker chains.
I think his lone wolf style attributes to his abilities to work quickly and efficiently.I wish I lived close to you Simp. I would hand you tools and sweep the shop floor just so I could watch how and what you do. I’m amazed at how much you know and how much you can do solo with these trucks. Thanks for sharing your knowledge with all of us!
Sweep the floors? Going to be at it awhile since I work on the field and grass more than anything.I wish I lived close to you Simp. I would hand you tools and sweep the shop floor just so I could watch how and what you do. I’m amazed at how much you know and how much you can do solo with these trucks. Thanks for sharing your knowledge with all of us!
That's one of the things that blows my mind. Not only does he make repairs and upgrades correctly the first time, but he's FAST. He's totally violating the Venn diagram of "cheap, correct or fast. Pick two." I think he even still has all of his fingers.I think his lone wolf style attributes to his abilities to work quickly and efficiently.
I'm on Adderall, that's why I am fast but the following list of people will tell you that if I am working on something and that wears off. Whew. You would be amazed at how I get anything done then.That's one of the things that blows my mind. Not only does he make repairs and upgrades correctly the first time, but he's FAST. He's totally violating the Venn diagram of "cheap, correct or fast. Pick two." I think he even still has all of his fingers.
I think there needs to be a "Connections" tab on the venn diagramThat's one of the things that blows my mind. Not only does he make repairs and upgrades correctly the first time, but he's FAST. He's totally violating the Venn diagram of "cheap, correct or fast. Pick two." I think he even still has all of his fingers.
What is the track speed record?For those wondering. Here is the race track.
