- 413
- 892
- 93
- Daytona, FL
I'm not sure if that will work as well, based on the picture. Do you know if the rubber is thicker than the metal?
user is 99% sure these are the ones he is using right now with success (it gets heavy use plowing snow too) but he is going to check... he ordered two sizes and is doubting himself a little on which one he ended up using.this was reported to work by another user... so I am not sure myself but I will ask him
yep... these are the ones (part number in the pics)user is 99% sure these are the ones he is using right now with success (it gets heavy use plowing snow too) but he is going to check... he ordered two sizes and is doubting himself a little on which one he ended up using.
5310-01-454-5553 Seal Washer Oshkosh 8HA5089 US Army 12418424-001 pack of 6. |
Prices for everything are a rollercoster when it comes to military surplus, and even more so right now with 2020/inflation/nonsense. A few months ago I bought like 10 packs of 5-6/ea for $3/ea, I think.Gee You better hurry, must be made of gold...
Going for 12 bucks each in ePay, have to shop.
Another on ePay is six for 25 bucks;
Part Numbers: 12418423-001, 673998Anyone know the blank banjo bolt (for spare tires) part number? And source?
Banjo bolt Washer ( Bonded Sealing Washer) for the wheel/lug air hose. | Spicer part | 673999 | Grainger | 39WD95 |
Coach, I was having difficulty finding a bolt that is not drilled for plugging my spare tire CTIS. I suppose I could find a shoulder bolt, but the army uses a blank banjo bolt. I guess this may be a minor hijack but near to on topic.
Banjo bolt Washer ( Bonded Sealing Washer) for the wheel/lug air hose. Spicer part 673999 Grainger 39WD95
Yellow parts spread sheet top of this fMTV forum.
