M939A2 starter issue
Badbronc78
Oregon
I havent been on here in a few years snd things have changed a lot.
My M939A2 was working fine parked it for a few months go to start it and it just clicks wont crank. I checked power to starter solenoid on starter and when I hit the start switch I get 25 volts to start terminal on solenoid. Solenoid clicks starter does not make any attempt to crank. Jumped two big lugs with a big screwdriver, lots of sparks starter didnt do anything. Did my starter just freeze up sitting, never had any problems with it before.
If I need a new starter I want to replace starter with a high quality gear reduction, soft start starter. Anyone recommend where to get one.
Its just weird I cant even manually bypass the wiring and jump it with a screwdriver. I havent tried turning engine over by hand because the starter doesnt seem to do a thing. Ive banged on starter with a hammer while jumping power to start terminal on solenoid and nothing.
Anyone seen this before?
Thanks
silverstate55
Unemployable
868
UT
@74M35A2
Contact member 74M35A2, he makes gear reduction starters for the 8.3 Cummins for these trucks (I still need to order one for mine too). Can’t beat the price nor service.
cbrTodd
479
Indianapolis, Indiana
Before you get into replacing expensive parts, check the simple things first. Have you load tested the batteries individually to make sure you have good amp capacity, not just good voltage? My deuce did the same thing a while back and it had a battery that had gone bad, but my charger said it had full voltage.
Jbulach
2,141
Sunman Indiana
#74M35A2
I think you need the @ symbol in front of the user name instead of the # to send out the bat signal. Somebody correct me if I’m wrong… again.
@74M35A2
Tow4
640
Orlando, FL
Plus 2 on checking the batteries. I've had bad batteries on my M818 act the same way after I had just shut the engine down. I thought the engine locked up. I barred it over and after a couple of revolutions, decided to check the batteries. New batteries solved the problem.
Also, if it's not batteries, try barring the engine over first. If it's locked up for some reason, you could destroy a new starter. Before you buy a new starter, if after trouble shooting you determine the starter is the problem. Pull the starter and run it on the ground with jumper cables. If it doesn't run, remove the solenoid and see if parts fall out. I had a screw come out of the solenoid on my M929 and the starter would just spin (and not throw out the bendix). Replacing the screw saved me several hundred $ for a new starter.
Badbronc78
Oregon
I have considered this and Im going to load test them before I do anything else. Thank you
Badbronc78
Oregon
I will do this too thank you.
