Here’s a summary…
I’ll begin by saying my truck was stalling about every 1mins-4mins. I noticed on my secondary fuel pressure gauge that I was losing fuel pressure causing it to stall. To me the truck was starving for fuel. I had changed filters a handful of times with no luck. I decided to empty the tank because I noticed some debris floating. To my surprise the tank liner was failing and chipping/pealing away. I thought ah ha, it just continues to plug my primary, filter after filter. Or so I thought. Since the tank was empty i decided to flush it again, acid washing the liner out and going from there, with no liner. After all this and a round of ALL new filters the truck still acted the same. I checked and cleaned all relief valving on the truck with no change, it continued to lose pressure and stall. I even had an in line filter BEFORE my in line pump, which I had changed also, so it’s not possible my pump was okuggedI even rebuilt the booster pump.
I decided the next possible issue was the aftermarket fuel pump I installed, an Airtex E8131. It had been recommended by many so that’s what I went with. Problem is majority of info you find states a flow rate of 35GPH, but, I found a 2022 copyright that stated 20GPH. This would absolutely cause an issue starving for fuel.
So I then decided to look for a new fuel pump. I came across and ordered a Carter 4600hp, although 12v(no biggie) it has a psi of 4.5-8’ish, and 50GPH flow and 3/8” npt inlet/outlet. I installed that pump, gave it correct voltage, and all has been fine so far.
Here is my current fuel setup…
Tank -> pick up tube -> wix 33248(prefilter) -> carter 4600hp pump -> wix filter head 24770 with wix 33405(water/fuel sep.) -> booster pump -> wix 3512(final) -> wix 3512(final) -> HH
All new 1/2” DOT plastic lines, and all new brass fittings up to the booster pump.
