- 3,325
- 1,283
- The actual midwest, NM.
I don't know if the 911 is bad for the injectors, but it's not something you should use unless the system is already gelled up and you need to get going NOW.
Regular anti gel can be used all the time without hurting anything. It's usually mostly a lubricity additive that also has anti gel properties. Shouldn't make anything smoke, though.
