A and B pillar reinforcement for armored doors?
M1028A1ShelterCarrier
71
Mammoth Lakes Ca.
After searching all of the parts TM's, I am unable to locate any diagram that shows reinforcement on the body side for piano style hinges. Can someone point me in the right direction in the TM (body side reinforcement) to mount heavy doors, share some pictures, or a source for parts. I found an a pillar kit online (pic below) but no idea if its even what I need or if the holes will align. The doors are going on an 1152. Thanks
TOM R
91
sewell n.j.
ive seen these for sale in the facebook groups for the heavy doors if todd hergott or greg alley are on here they would be a start to ask
Action
1,556
East Tennessee
I dont know if your door hinge holes line up, but those 2 skinny green pieces are pretty much just spacers. Inside armor fits over them, and then you will need armor on the outside. Those doors are flat. The side of the HMMWV is not. Probably need spacers between door hinge and body, too.
Retiredwarhorses
4,129
Brentwood, Calif
feel free to call the shop…Armoring HMMWV’s is something we’ve been doing for many years.
71
Mammoth Lakes Ca.
These doors have the bend and fit perfectly. I plan on fabricating inside channel blocks with bungs unless I find something already built. The above pictured spacers appear to me that all of the notches are to clear the rivet pattern on the inside? I may buy those and mod them if necessary with plate steel and bungs.
Retiredwarhorses
4,129
Brentwood, Calif
there are numerous armored door types, up until the later doors did they all use the same hinge bolt pattern. Most doors are flat to allow for the perimeter armor, early stuff had the contour like regular x-doors but were different hinges and bolt patterns, so you can’t use the current issue reinforcement backing supports.
Post a pic of the doors you have
Retiredwarhorses
4,129
Brentwood, Calif
So I went ahead and ordered the above pictured stiffeners for nothing else than to get the interior rivet pattern. I may end up drilling the hinges to fit the old pattern if it's off. I have all the parts except glass and b pillar reinforcement to complete these doors now.
that’s part of the MAK…Marine Armor Kit
i just sold all my MAK hinges, There are 2 PN’s for the Hinges.
86humv
497
Texas
The silver hinge side that goes to the body is the side with all the slotted holes
Retiredwarhorses
4,129
Brentwood, Calif
That is exactly what I was looking for so Thanks! Is that just a spacer for the b pillar so bolts can run through without crushing or is threaded? Any idea the NSN or where I can get two? Thanks again
had to have them reproduced, impossible to order darn near. They are inserts into the B-pillar lower post and riveted in.
71
Mammoth Lakes Ca.
More of a spacer. It fits in the skinny part of b-pillar that makes the door jamb to stop it from crushing.
post #1 mentioned an m1152 but shows an m1151 dataplate. Either way, you may already have the skinny b-pillar spacers.
The 1151 picture was from the web of the part I need for a M1152. Thanks
