Great looking FLU419.
The FLU419 has air over hydraulic brakes. Without adequate air pressure, you can't stop the Unimog, even if going very slow. When I got mine, the crossover air line from the regulator/unloader to the air tank was corroded solid, hence no brakes and a lot of other stuff didn't work. I replaced the 10 mm corroded steel line with a 10 mm 316 stainless steel line and a new unloader I found on Ebay, along with a few fittings I got from EI. Now everything works and great brakes. I had to adjust the new unloader to the correct pressure for the FLU, which took about 5 minutes. If you take any air lines / fitting apart, be very careful as the fittings break very easily.
