3up
- 97
- 28
- nevada boulder city
6 broken 6 good tomorrow is drill day
1/4" dot fittings.New to air lines they look like AN fittings but not sure. Im plumbing in an air seat what size are the fittings on the E brake ? Does it go by outside diameter? And i saw a you tube about removing the air valve for the T case does anyone know how to find it? Thank you
Awesome thank you1/4" dot fittings.
You do not need to t into your ebrake lines run thru the floor to the frame. Any yellow line you find is on the pressure protection side.
Yellow lines are what you are looking for with the transfer case
May I ask how it went getting the snapped bolts out ?Finally got it finished
One more thing to try another guy was doing his too. Smack them with a hammer to shock the bolts then use an impact, he got all 12 out that was his was a rusty one too.May I ask how it went getting the snapped bolts out ?
I have to do the same job sometime soon
