Water in crankcase
TOBASH
3,490
Brooklyn, NY
Not the first StSo member with water logged block that was started and worked fine.
Nothing to lose
twisted60
250
Jupiter, Florida
My M1152 came from Albany with about 2qts of water in the engine. I drained and filled with diesel, let it sit overnight then drained it again. Serviced with 6 qts of oil, 2 qts of Molly lube Eng flush and new filter. Ran it 30 min at idle, drained and removed filter. Serviced with fresh oil and new filter. Drove about 100 miles, changed oil and filter again. She’s been running great since.
myimpala1
20
New Jersey
Thanks for all the input everyone. I apologize for not stating that the intake was on the vehicle and didnt apear to have been off . I am going to drain it, change the filter, check with bores borescope, put in diesel and oil. I may drop the pan and check.
TOBASH
3,490
Brooklyn, NY
Honestly, if I were you, I would drain everything and pop the glow plugs and leave them out and see if the engine cranks and if it doesn’t I would put a long spanner on it and see if you can turn it manually.
Dropping the pan and all of that is fine if everything else fails. Right now you just need to know if the engine will turn over. You need to pull the glow plugs to release pressure in the cylinders in case the cylinders are full of water. Then spin the engine and if it spins easily, replace the glow plugs and go from there.
Action is a great guy and I agree that dropping the pan would be the next step, however if this engine spins freely, think of all the work you have saved.
Start from the foundation first. An engine that spins is not seized.
IMHO
frank8003
4,985
Ft. Lauderdale, Florida
IMHO
Kroil is your friend, pull the injectors and put Kroil or/our favorite ATF 50/50 miture after draining crankcase.
Give it time passing and see what drains out before you "move" the engine.
TOBASH
3,490
Brooklyn, NY
I use Marvel Mystery Oil with great success, BUT Frank is correct and that is the same concept and there is more than one way to skin that cat.
19,766
Company that I worked for had machinery that would be "left on the lot" sitting waiting for the next job. Some of that machinery was used for a few weeks, then it would sit again used for pulling wire through stringing blocks. Those motors would be field prep'd with MMO (Marvel Mystery Oil. Warm (not hot) up the motor and gas engines got MMO down the carb. Diesels were similar, but into the glow plug ports then crank it again for smoke effect.
We managed to crank and have "happy trucks" that way and "open to the air" cylinders were found to be in good condition with that protection...
That stuff can be magic in the right hands!
myimpala1
20
New Jersey
Ok so where I am at now is. 5 gal of clean water removed from pan. Now at almost 2 gal of milky white sludge. I am thinking about filling with diesel and pulling glow plugs next to see if I can get it to turn.
MarkM
1,972
WOBURN. MA.
Try to pull it by hand first to see if it moves. That amount of water is a really bad sign.
Mark
Mogman
9,589
Papalote, TX
Have you tried to turn the engine, that is a lot more than a "couple quarts" .
Also where are you going to "scope" it, the pre-cups will prevent you from seeing squat.
Mogman
9,589
Papalote, TX
Nothing to lose
Sorry Tobash, all the Marvel Mystery oil in the world would not have fixed the engine I showed above and I am willing to bet this one is in no better shape.
It takes a LONG time to get that much water into an engine, unless someone used a hose and filled it a week or so before he picked it up there is allot of damage inside that engine, water and machine parts do not mix well.
Now having said that I hope I am wrong but I rarely am...
Maxjeep1
1,916
Las Vegas Nevada
I would have filled it with diesel as soon as I drained it. If it’s not ruined it will be soon. I would still try to get it running.
