McSpeed
- 293
- 63
- Palmer, AK
If you use your imagination and close your eyes it tastes like a blue slurpy slushy drink from the corner stop and rob. Actually it just tastes like refreshing God’s country.What does the water from the blue ice taste like? I always wondered that since a kid.
Just buy Rubber Duck D-ring setup meant for H1's. It will work out cheaper and better. Search rubber duck 4x4I am dropping the truck at a local welding shop and kicking in a large chunk of hard earned money to have the stock brush guard heavily modified. Will use square tubing. It will go up to tue lift hooks on the hood like the Predator grill guard. Should be able to bolt the Jack and other things to it and better protect the nose from minor collision. Running these trails have convinced me the value of the grill guard.
I never heard of them before. That’s a nice guard. Looks like shipping to a residential outside of the lower 48 will hurt. My local welder is making a design out of square tubing. We sat down and talked about it. Since nothing on the truck is round. He will try to mimic the hood lines in square.Just buy Rubber Duck D-ring setup meant for H1's. It will work out cheaper and better. Search rubber duck 4x4
EDIT -
H1 TreeHugger™ Brushguard - RD4x4
Provide the ultimate protection for your hood and off-road lights while providing an unobstructed view of all of the marker lights with the RubberDuck 4x4www.rubberduck4x4.com
If the winch doesn't pull hard enough, simply add a snatch block and double the pull, at half the speed. No big deal, unless you're impatient.Due to shipping, delays, and other issues - I'm back to play A - to have a bar built. It won't be as elaborate - but should do the job. Dropped the truck off this morning. I also picked up a winch for it so we can build out a mount. Went with a SuperWinch 10K - I know people argue for 12 K - and if some is good - more is better. But, my truck is light weight and a winch should be 1.5 x the weight - so, 10K will work. For something I hope to never use. Plus, thanks to the world being on fire - getting a 12K wasn't going to work right now. The Superwinch has the longest warranty I could find - and it said made in USA- but now I think it was designed here...made you know where. A nice feature is a light built into the spool reel area - and it came with a wireless and wired remote. I also picked up some of those large ammo/smoke canister cans and mounted them in existing holes on the rear fenders to give me some more weather proof storage.
I think from what all I’ve read the snatch block is smart no matter what. better slow and out than not The instructions also talk about using a shock bundle. I need to figure out what that is and order one.If the winch doesn't pull hard enough, simply add a snatch block and double the pull, at half the speed. No big deal, unless you're impatient.
He was going backwards thru the drive-thru to look cool.I’m concerned about the McDonalds Golden Arches in the backround. The military seats are already too far forward, so if you start sucking down too many BigMacs with cheese you might no longer fit.
Just saying. LOL
Really nice work!
Well you know Ronald is my older better looking brother.I’m concerned about the McDonalds Golden Arches in the backround. The military seats are already too far forward, so if you start sucking down too many BigMacs with cheese you might no longer fit.
Just saying. LOL
Really nice work!
