Erik Erickson
- 25
- 13
- Northern New Hampshire
Hi All,
I just purchased a 2003 M1078A1 from Govplanet. Upon delivery it was said that the Transmission Control Module may have an issue. I charged up all 4 batteries successfully. With the normal start up procedure, it would not start. Dash lights came on normally. I removed the starter relay, jumpered it, and the engine fired right up with the push button on the dash. I heard the transmission control module may be the problem. I pressed some buttons on the transmission module to see if it was operational without the display, but no luck. Nothing worked. I shut down the engine and came in to post here.
Any help is greatly appreciated.
