mijon
- 0
- 0
- Fenton, MI.
A little Run Down:
I looked at the wiki under plug system for a Cucv M 1008. Used a Test Light and figured out 6 glow plugs where shot. Replaced the 6 gp's with new ones (Wellman 070). Truck is stock, no modifications. Turned on key, took about 45 seconds for the WAIT light to go out. I heard the "click" sound from the the relay before the wait light went out, then about 3 seconds later the WAIT light did go out. I then took a voltameter and checked voltage on the top terminal on the glow plug relay. It was reading voltage with the key OFF.
I'm thinking the problem is the glow plug controller. From what I read on the wiki if there is voltage present on the top terminal on the glow plug relay, with the key OFF, and if you hear a "click" sound from the glow plug relay with the key turned ON, your glow plug relay is okay. The problem is the operation should keep cycling (repeated "clicks" from the glow plug relay) and it doesn't. Which makes me think its the Glow Plug Controller. I watched the video "theory of operation video" in the stickies at the top of the forum. And what I took from it was that was the glow plug controller, cycles the whole operation.
1.WAIT light to
2.Controller CARD to,
3.Temp Sensor to,
4.Glow Plugs to,
5.The operation cycles again.
( Getting Proper Voltage from both Batteries)
Question:
My question is what do you guys think the problem is before I start throwing more money at? Can anyone point me the right direction with the TM's? I've read some on the Glow Plug Operation, but couldn't find anything on how to diagnose the GP Controller itself. Any thoughts or information would help me out a lot.
1.WAIT light to
3.Temp Sensor to,
4.Glow Plugs to,
Question:
