Robtstee
- 12
- 3
- Orlando, FL
First, I know how to test an alternator for function. I am concerned with connecting this alternator. Had a problem and burnt all the fusible links and smoke came out of Gen 2. Fixed all the links and installed a new alternator. Marked all wires when disconnected. It is wired per the diagram. Have tested for negative terminal isolated from case. Went to put on Bat 2 negative, got sparks. Disconnected and traced till I found the + term on Gen 2 to the 24v Buss was causing the sparks. With all wires disconnected except the neg terminal I've got 12v on the neg terminal, 12v on the exciter tab, 12v on the wire to the 24v buss and 12v on the little pin. Exciter wire 0v with key off, 24v on. New alternator, but the situation was the same with the old one. This may be all be normal but, I am unfamiliar with this setup and would like to know for sure before burning anything else up. Thanks in advance.
